Page 49 of 49 FirstFirst ... 39474849
Results 1,201 to 1,209 of 1209
Thread: Razorlab's 'simple' build
  1. #1201
    Jan 2019
    N.E. Indiana
    32
    What do injectors have to do with oil in a cylinder?
    My assumption was that it was running richer than the rest, and not an oil consumption issue. Wouldn't oil also cause detonation/knock issues as well?
    At first glance it appears to be carbon fouling, but the picture isn't clear enough to tell. Oil fouling should be shinier, last I recall.
  2. #1202
    East Coast, somewhere
    2,547
    239 Post(s)
    So... swapping the injectors didn't change anything. Still #3 dirty plug and oil in #3 cylinder.
    My mechanic really wants to get this figured out so he is going to start the tear-down (again) end of this week. I'm assuming the engine is going to have to come out and get torn-down (again). One thing is for sure, I am not using the original machine shop. Probably will contact Arlington, who did my CNC head and see if he wants to make sure my block is 100%.
    This whole thing the last two years has really taken me on a roller coaster. Between this, our cross-coast move, finding a place to live, starting a new job and prepping for our wedding, I am feeling super overwhelmed so I am going to log out of the forums for awhile, take some focus off this car, let the shops do their things and attend fully to the rest of my life activities.
    See you all in the future at some point.
  3. #1203
    Senior Member MetalAF's Avatar
    Oct 2017
    Ohio
    174
    9 Post(s)
    Go enjoy life and take care man!
  4. #1204
    Senior Member LeesEvoX's Avatar
    Houston, TX
    1,546
    87 Post(s)
    Good luck razor. All the best to you.
    We will all be on the look out for the wedding invites
  5. #1205
    1,563
    79 Post(s)
    @razorlab let's meet up sometime man
  6. #1206
    Jan 2019
    N.E. Indiana
    32
    Really is a shame to see that it is oil again. I was hoping it was the easy fix..
    You take care of yourself. I hope the move and the settling in goes much smoother than the car seems to be
  7. #1207
    2,547
    239 Post(s)
    Update.
    Leakdown was conducted with the cams out. Did leak down with the piston at TDC, fully at the bottom of the stroke and in the middle. Zero leak down on all three.
    Stumped....
  8. #1208
    Jan 2019
    N.E. Indiana
    32
    Update.
    Stumped....
    At that point the only thing I could surmise would be an issue with the oil control rings or bore itself , having a spot that is slightly out of round or worn. Other than that, there should be no way oil is getting in there unless the head is lifting/high spot on the deck. Even then would be about impossible to get oil over there before coolant.
    I would be upset too.
  9. #1209
    columbus, ohio
    812
    4 Post(s)
    i had a a cylinder go out of round, and it burned oil, only sign was smoke on dyno and qt of oil everyone 1k miles, leak down showed 25% leaky
    ERL sleeves
