Page 37 of 37 FirstFirst ... 27353637
Results 901 to 917 of 917
Thread: Razorlab's 'simple' build
  1. #901
    997
    36 Post(s)
    Tell us about oil temps? Were you able to install fog deletes?
    Current
    2.05L/darton,ProH,CP 10:1 w/Ultimate pins. IWG9174 .92. GSC-S2. 4P head +1mm In/Ex. Self tuned
    Past: 2.4L,Manley94,Pro-H,Wiseco,10:1,Darton,4P head,GSC all,Supertec valves,FR 9174 IWG .92,2x450 Walbro/EP control,ID1700,Flex,OSGiken triple. <--KABOOM
  2. #902
    301
    6 Post(s)
    Track day number four with the new build was yesterday. I'm starting to be much more comfortable with the car and it's showing. I broke my personal best by almost 2 seconds and now approx 1.3 secs away from my goal. Super happy with the car, it's f'in fast as hell, I'm going Hans device shopping this weekend because of it.
    I'll do a more detailed write up with data and such in a couple days once I get some time. For now, here is a video of my new personal best 2:01 lap time.
    look at the schroth flex. Was pretty comfortable when I was shopping neck restraints
  3. #903
    2,073
    172 Post(s)
    I was able to install the fog deletes. I got all excited when I did because the difference visually of how much more of the oil cooler is in direct air now is HUGE.
    However, I just overlayed data from yesterday and a session last month with comparable outside ambient temps and the oil temp is *almost exactly the same*. Follows basically the exact same plot...
    So.. much disappoint. I think maybe I need to make a custom duct to force more air into the cooler now. The OEM duct doesn't seem to channel as well as it could for this cooler.
  4. #904
    997
    36 Post(s)
    Damn, indeed a disappoint. 264*F is up there. What were the ambient temps?
    A custom cooler guide may make a bit of a difference, but i dont think it will make much.
    This is what i'm thinking: I think the whole oil cooler plumbing system has a design flaw. the reason being is that when the thermostat opens it doesn't "redirect" oil flow thru the cooler exclusively. When the t-stat opens it simply opens a "parallel" loop for the oil to flow thru. Depending on the restriction that the oil cooler presents itself as, the oil flow thru the cooler may be very minimal. So the issue here may lie in the fact that there is simply not enough flow thru the oil cooler. I wonder if you placed a temp sensor at the cooler outlet, i bet you you would see a significant temp drop there. But not having enough of the "cool" oil going back into the engine is not reducing the overall temps. (I'm pretty sure that's how the t-stat is set up here; i may be wrong).
    This makes me question my whole fan install...
    Current
  5. #905
    Oct 2015
    Brazil
    237
    38 Post(s)
    I've seen track guys installing a secondary oil cooler in front of power steering line loop, behind upper grill, much like SSP cooler, but keeping the stock location cooler.
  6. #906
    dallas
    316
    19 Post(s)
    i'd consider changes if oil temps start going over 280. until then a good quality, appropriate weight engine oil is enough to handle those temps.
  7. #907
    2,073
    172 Post(s)
    Quote Originally Posted by momo View Post
    Yea that is what I have been collecting from asking a bunch of higher horsepower track car owners. I think I am good for now.
    So... guess what happened again? Damn car fritzed out again and lost power. Car was solid all day long and in the 2nd lap of my fourth session, every time I shifted to 4th under WOT the car would fritz out and loose all power, just like before. However this time it was repeatable and not just a one time thing. It was more dangerous this time as well because I almost had a C63 run into the back of me going down the straight since I was hauling ass one second and then the next, nothing.
    ONLY happened in 4th gear and after doing that four times while trying WOT in 4th it all cleared up on it's own and I was able to go 100% the rest of the session. So odd that it just clears up on it's own. Now that I know it only does it in 4th, I'm going to start looking at any gear/speed related tables in the ECU.
    Here is one of the instances caught on log: https://datazap.me/u/razorlab/thunde...zoom=7510-7949
  8. #908
    2,087
    168 Post(s)
    Intake coupler collapse?
  9. #909
    2,073
    172 Post(s)
    Quote Originally Posted by Black E View Post
    Wouldn't that happen more frequently though? Like I said, after these couple instances I was able to continue the session with WOT in all gears with no issues.
    Also, all the data I have seen from coupler collapse is boost dropping hard from the turbo being choked but never the zig zag of everything else like TPS, etc.
  10. #910
    2,087
    168 Post(s)
    Has it ever happened on the street?
  11. #911
    2,073
    172 Post(s)
    Only once, and also in 4th gear. This was the first time it was repeatable past a one time event.
  12. #912
    2,087
    168 Post(s)
    Does the car run more boost in 4th?
  13. #913
    2,073
    172 Post(s)
    Nope.
    Notice that TPS (Throttle Body) is one of the items that goes all fritzy. Here is part of the log showing everything okay in 3rd and then in 4th, my foot is commanding full throttle (APP) but TPS is going all nuts. I then back out, then I try it again, and the TPS does the same thing:
    Here is another part of the log, later in the same session, in the same straight, 3rd, 4th and 5th gear with no issues:
    https://datazap.me/u/razorlab/thunde...om=20230-20813
  14. #914
    Member rapairmanrage's Avatar
    44
    4 Post(s)
    I experienced something similar after applying the spark cut patch. Essentially when launching the car from a standstill in 3rd or 4th gear the ecu would go into launch, cut boost and hold rpms.
    Might not be a bad place to start if you have that patch applied.
    700whp 9180EFR 2.0L
    Self built, WTF Tuned
  15. #915
    dallas
    316
    19 Post(s)
    yea it does sound like a rogue safety patch in the rom cutting TPS. id start chasing all those safety nets in the tune which can cut TPS.
  16. #916
    2,073
    172 Post(s)
    Quote Originally Posted by rapairmanrage View Post
    No spark cut patch applied but good suggestion!
    Yea I am going to look through. However, most TPS "cut" features just drop the TPS down to flat %. The zig zagging stuff is what is perplexing me.
  17. #917
    dallas
    316
    19 Post(s)
    that is true. it could be mechanical, check throttle wiring and grounds, perhaps even voltage related.
