Page 42 of 42 FirstFirst ... 32404142
Results 1,026 to 1,046 of 1046
Thread: Razorlab's 'simple' build
  1. #1026
    1,164
    54 Post(s)
    Something doesnt add up. Which bolts are these? The ones from UK? Are these fittings the same height as MAP fittings? You may have to get the long bolts from ebay and cut them off.
    It still looks like you have some space between all the pieces. Can you compress the assembly more? The way that the Mishimoto fittings come from the box is very similar to that actually. THe bolt doesnt stick out past the fitting that much (but more than you are showing)
    Current
    2.05L/darton,ProH,CP 10:1 w/Ultimate pins. IWG9174 .92. GSC-S2. 4P head +1mm In/Ex. Self tuned
    Past: 2.4L,Manley94,Pro-H,Wiseco,10:1,Darton,4P head,GSC all,Supertec valves,FR 9174 IWG .92,2x450 Walbro/EP control,ID1700,Flex,OSGiken triple. <--KABOOM
  2. #1027
    2,251
    194 Post(s)
    Welp, banjos don't matter now.
    I was going through the car in prep like I do before every track day. Taking plugs out to check everything over, my heart sank. Oil on plug, oil in cylinder. The weird thing is the car ran fine.
    Going to do a compression check but not when it's night time so my neighbors don't hate me.
    Super bummed right now. I hate cars.
  3. #1028
    Senior Member Exyia's Avatar
    1,137
    80 Post(s)
  4. #1029
    1,164
    54 Post(s)
    That sucks. Hopefully its something simple.
    Current
  5. #1030
    2,251
    194 Post(s)
    Not sure if it's coincidence or not, but #3 is the same cylinder as before...
  6. #1031
    2,180
    174 Post(s)
    Compression and leak down tests would be my next move.
  7. #1032
    2,251
    194 Post(s)
    Quote Originally Posted by Black E View Post
    Yea, going to do a compression test next. I didn't do one when I discovered this last night because I didn't want to upset my neighbors. :P
    Unfortunately I don't have the tools to do a leak down test at home. I have a small little compressor that is really only good for filling a tire or two.
  8. #1033
    Senior Member DereksX's Avatar
    St. Louis, MO
    1,333
    52 Post(s)
    NOOOO! Fingers crossed man!
    WTF 2.0 in Progress
  9. #1034
    1,164
    54 Post(s)
    Razor, any updates?
    Current
  10. #1035
    64
    How many miles are currently on the motor?
  11. #1036
    2,251
    194 Post(s)
    Razor, any updates?
    Nope, been busy. Probably won't be able to touch it again until this Sunday
    Quote Originally Posted by Kento240 View Post
    Approx 4k
  12. #1037
    Global Mod of Things DKevoX's Avatar
    1,822
    94 Post(s)
    fuck.
    Fingers crossed man.
  13. #1038
    2,251
    194 Post(s)
    @mityaz
    Received the longer double banjo bolts from ebay that you linked to. These are probably some of the shittiest quality things I have seen in a long time. Good lord. If somebody didn't checked before they used these it would cost them a motor... I can't believe I payed $17/each for this crap.
  14. #1039
    1,164
    54 Post(s)
    Can't win, huh?
    Now you just have to shorten the bolt a bit and make the body narrower so that it screws into block fully. I actually widened those holes with a dremel for better flow.
    Current
  15. #1040
    710
    4 Post(s)
    fack that sucks
  16. #1041
    2,251
    194 Post(s)
    @Black E, others
    If I where to say, send my spare cylinder head out for service and prep, who are the best now? I heard of all these issues you have had with your heads. Who do I trust?
  17. #1042
    1,164
    54 Post(s)
    I took a picture for you
    Current
  18. #1043
    2,180
    174 Post(s)
    @Black E, others
    English is the only shop who’s done what they said they would do and did it well. But they are really expensive and take forever.
    Find out what may be the problem and figure out where to send it from there. I’m guessing it’s valve guides or seals if the short block is good.
  19. #1044
    2,180
    174 Post(s)
    @mityaz you’re fucking crazy lol
    No way in hell I would put that thing anywhere on my engine.
  20. #1045
    1,164
    54 Post(s)
    Kept my oil temps at 230* during a whole 20min track session tho...
    Or are you talking about my hands?!?!
    Current
  21. #1046
    2,251
    194 Post(s)
    I agree with @Black E no way would I put that on my engine. I'd rather pay somebody to make custom bolts for me.
    Thanks for the info on the head @Black E. I was kicking around the idea of maybe trying Curt Brown?
    Also, today I put another set of used plugs in and drove the car around for about 15 minutes to warm it up so I could do a warm compression check. I never saw any smoke at WOT (I only WOT for about 1000rpm just to be safe) and never saw any at idle.
    The plug came out with a little oil on it, not sure if it was from the oil in the cylinder or from whatever is putting oil into the cylinder.
    I did a compression check and it came out solid so that made me feel better that it might just be a leaky guide or seal. Either way the head is going to have to come off. I'm going to try and make an appointment with my local shop to do a leak down test and take the head off.
