Page 6 of 6 FirstFirst ... 456
Results 126 to 130 of 130
Thread: Zabes TT2 Evo Build
  1. #126
    403
    18 Post(s)
    Also, still working out scheduling with the composite shop so should be beginning fabrication shortly once that's all taken care of.
  2. #127
    403
    18 Post(s)
    Picked up a racecapture pro mk3 and a shift/warning light with autosports black friday deal. Once I get it, will work on swapping all my current sensors over to it. Also plan on getting an IZZE Racing tire temp/pressure sensor kit
  3. #128
    1,500
    78 Post(s)
    Im excited to see the development of this withe the tire temps. Please let us know once you figure out how to read the CAN protocol (im sure psfp can help with this).
  4. #129
    403
    18 Post(s)
    This is the system I'm looking at. Will help a lot with getting suspension setup dialed in.
    http://www.izzeracing.com/products/t...ng-system.html
  5. #130
    403
    18 Post(s)
    quick update:
    Still waiting on everyone to agree to the NDA terms for the aero development. got the racecapture initially installed and configured, just need to finish building the sensor harness for it.
