Results 1 to 10 of 10
Thread: Need some evo help (feels gd to post these threads again)
    Senior Member LeesEvoX's Avatar
    Houston, TX
    1,526
    87 Post(s)
    So I'm sure the majority of yall have heard I got my evo back. You know, since I didnt shut the fuck up about it for days lol
    I am starting to do some little things that have been bothering me for a while.
    Starting with the TWM cage. I put the stock cage and shifter in today, and while doing it needed some air flow. So tried to turn the ignition on for the fans, which worked. But I now have a "service fast key" yellow warning on the dash.
    Like a dumbass I didnt unplug the battery. And when taking apart the center console there are a few plugs to disconnect.
    Is it possible disconnecting one of these plugs has caused this? I thought they were just for the AWC, and cig lighter. What gives?
    Is there anything I can do about this? The car will still lock, unlock, and start.
    Come on brethren. Help me out with my first problem since getting the evo back 4 days ago! hahaha!!
    Oct 2015
    Brazil
    322
    67 Post(s)
    There is a module/antenna/something else under cup holder area in my car, not sure if it is the same for every car. Try to connect everything back to see if the warning goes away.
    Houston, TX
    1,526
    87 Post(s)
    Quote Originally Posted by psfp View Post
    Yeah. Got everything plugged back in but still get the error
    Houston, TX
    1,526
    87 Post(s)
    Just keeping this at the top for some help
    Senior Member staywide8's Avatar
    Mar 2016
    110
    5 Post(s)
    I'd try pulling power to the battery now and seeing if that will reset the code. I doubt its a hard code (something like a srs light) so it should be fine after pulling power for a minute or two.
    Houston, TX
    1,526
    87 Post(s)
    Quote Originally Posted by staywide8 View Post
    Thanks bud. I'll give this a try tonight. Don't know why I didnt think of this to begin with lol.
    Senior Member ak47's Avatar
    1,843
    10 Post(s)
    I will exorcise your car.
    Houston, TX
    1,526
    87 Post(s)
    Quote Originally Posted by ak47 View Post
    You know. In not a religious guy. But at this point with my car I'm might be open to anything hahaha
    Oregon
    771
    25 Post(s)
    FWIW, have you tried a new battery in your fast key?
    Houston, TX
    1,526
    87 Post(s)
    Quote Originally Posted by BulliesAndBoost View Post
    So. Just got home after work. Was going to disconnect battery. And thought to have a look first. Jumped in the car, no fast key warning. Lol. So I guess one of the plugs under the center console has something to do with it.
    Side note.
    After putting the stock shifter and cage in... good God i forgot how awfully sloppy it is. Ugh.
