Results 1 to 4 of 4
Thread: Help with Data logging with cobb AP v2 + external WB
    Junior Member kobi411's Avatar
    May 2018
    12
    hey guys, not my Car but i would like to help a friend with a 2003 wrx data logging on his cobb v2 AP with glowshift Wideband..
    i need some guidelines what to do with his car..
    we tried downloading Rom raider and glowshift is not supported just common aem, Innovate, zeitronix etc.
    my question is how are we able to datalog so we can send it to his tuner, tuner gave him a base map (put a better turbo + bolt ons)
    his tuner doesn't know how to with his current set-up of the cobb v2 and glowshift.. and no help Local Either, tuner wants external AFR readings
    glowshift wideband has 3 wires for data logging purpose.. (+) wideband (+) narrowband (-) ground
    can we log it it with Cobb AP v2 or does he need a v3?,
    i dont see cobb supporting the glowshift gauge i think, correct me if i am wrong..
    please help, thanks in advance...
    Senior Member ak47's Avatar
    1,822
    10 Post(s)
    V2 I don't think so. V 3 has a aem wide but I don't know how.
    He needs a local shop or go open source.
    May 2018
    12
    hey thanks.. just figured this out, so basically needs AP3, log with rear o2 sensor
    the signal from wideband has to replace the rear o2 sensor wire that sends signal of 0.5v going to the ecu
    then edit the data in AP3 to log rear o2 sensor..
    it doesnt help he is being cheap, but oh well...
    1,822
    10 Post(s)
    V2 is not gonna work anymore. They are being phase out. My car is on Dyno and suddenly they cannot connect anymore. So I have to get the V3 but on 50 discount but I just to return the V2 to them.
