Results 1 to 13 of 13
Thread: Boost Gauge Reading Wrong
    Dec 2017
    29
    I have been having trouble with my boost gauge. I can't recall it ever reading reliably since Buschur's installed it. Well, definitely not since I started really watching it closely. It read +11 psi with the engine off. I pulled the hose going to the sensor and reattached it and then it read +4 psi. It was reading +22 psi while cruising where it should have read vacuum and it just bounces around all over. It's an AEM gauge and my AEM AFR Gauge shares the power and ground with it and it reads correctly.
    I was thinking about getting a new sensor, but they're $70. Any insights or thoughts on this. I'm on an Evo X EFR 8374 integrated BOV. Buschur did the install, also I'm still learning all this stuff so I'm not certain where to describe where it's T'd into. I can get pics.
    Sent from my iPod touch using Tapatalk
    Senior Member ak47's Avatar
    1,842
    10 Post(s)
    Quote Originally Posted by cerealkeller View Post
    Ask Buschur since he installed it. Looked like those hose plugged.
    Senior Member LeesEvoX's Avatar
    Houston, TX
    1,558
    87 Post(s)
    This happened to my boost gauge.
    It ended up being the sensor. I have a prosport evo gauge, and when I called them they apparently had a new revised one..... which was waterproof LOL!
    As soon as I switched it out it read perfectly
    Sent from my SM-G950U using Tapatalk
    1,842
    10 Post(s)
    I have a cheap glowshift boost guage since 2009. The reading is very close to the tuner's reading during Dyno. I wonder why an aem sensor will crap vs a cheap one.
    Senior Member alejo's Avatar
    Oct 2016
    154
    Quote Originally Posted by ak47 View Post
    I installed a brand new aem x-series oil pressure and it came with a bad sensor straight outta the box ! just saying
    ATP GTX3576R GEN 1
    BEST ET 10.9@132
    1,842
    10 Post(s)
    Quote Originally Posted by alejo View Post
    Wow really AEM is a brand they should check their quality control. My AFR is AEM too but my Boost and ST temp is cheap one...Glowshift.
    Oct 2016
    154
    My other gauge is the AEM Fail Safe, everything came working perfect ! but this X-series failed !
    ATP GTX3576R GEN 1
    BEST ET 10.9@132
    Senior Member razorlab's Avatar
    East Coast, somewhere
    2,581
    241 Post(s)
    As an FYI, AEM sensors are not engineered or produced by AEM.
    Oct 2016
    154
    Quote Originally Posted by razorlab View Post
    Have you replaced any gauge sensors ? assuming you are using AEM. Do you know any comparable brands for replacing this type of sensors ?
    Thanks,
    ATP GTX3576R GEN 1
    BEST ET 10.9@132
    2,581
    241 Post(s)
    Thanks,
    The stainless steel sensors appear to be kalvico sensors. I use AEM harnesses on most of my kalvico sensors.
    Really, as long as you find sensors that have the same 0-5v output, you can use them with AEM hardware
    https://www.aemelectronics.com/produ...l-psig-sensors
    Oct 2016
    154
    Thanks,
    Good deal , Thank you Sir
    ATP GTX3576R GEN 1
    BEST ET 10.9@132
    Dec 2017
    29
    Been busy, sorry for the delay in responding. All my gauges are AEM. Oil Pressure and AFR work perfectly. No, I haven't switched out the sensor and it appears to be brass.
    So I can switch out a new sensor and plug it in straight out of the box?
    Yes you can swap the sensor straight up.
    We can get you genuine AEM parts if you need any.
    On other boost gauges, to note, sometimes the auto-calibration for outside pressure will be thrown off if the gauge is powering up during cranking/engine start up. Not the case here, but just wanted to note.
