Results 1 to 14 of 14
Thread: fuel line failure
    42
    fuel line failure
    while casually driving home i had a immediate smell gas and car started to stumble. there was a failure from the AN to quick connect fitting that connects to the hard line by the firewall . this is a radium rail.
    im wondering if this was a random fluke or is a more dependable fitting out there. was not a fun day dealing with this in rush hour traffic, and this was the best case scenario.
    1,372
    72 Post(s)
    pictures?
    What do you mean by a failure? A failure of you tightening the connection? Usually the AN lines are pretty good for leak proof seal.
    2,394
    218 Post(s)
    If it's the quick connect with the plastic tab fitting, doesn't surprise me. Make sure you use this type:
    42
    i bought it as a whole kit from radium, its the hardline quick connect to AN adapter. not the same one as pictured above, yes has 2 plastic tabs sticking out on each side. failed as it came completely off from the hardline and sprayed fuel all over the engine bay.
    ill give radium a call but they gave me shitty customer service before so i dont expect much.
    razorlab: thanks ill take a look for that fitting after a talk with radium.
    1,063
    31 Post(s)
    When i put my recent engine in, i thought i had everything buttoned up. I specifically remember connecting this plastic connector into the stock fuel rail hardline. Within 30 seconds of turning the engine on, it popped off and sprayed fuel everywhere. Cleaned up the fuel, reconnected it, and hasn't happened since. Me thinks it probably didn't lock in, even though i distinctly remember connecting it securely.
    Senior Member doom26464's Avatar
    Canada
    1,376
    17 Post(s)
    Its a bitch to kind lock on. But once you get it on seems like it be a pain in the ass to ever get off.
    Mine been on there for a few years no problem
    12 GSR-GTX3576R
    Chet Rickerman tuned
    490whp 405wtq
    05 SRT-4- Project "turbo skittle"
    Needless torque tuned
    42
    that was also my first thought, that it wasnt really snapped in, but its been on the car for likea year/ 2k miles. i tried to re attach while stranded and no, it just slips off.
    2,394
    218 Post(s)
    If it wasn’t engaged to begin with it would have popped off the moment you went into throttle at 50psi+ of fuel pressure. It probably failed.
    Use what I posted or radiums new commectors that have the same type of design.
    Really glad you only got stranded. Like you said, could have been a lot worse!
    Senior Member Hiboost's Avatar
    143
    10 Post(s)
    If your engine bay lit on fire it could have been MUCH worse, time to upgrade that connector!
    Chris Wirth
    Build: HiboostTuning.com
    2011 Octane Blue Evo X MR
    Best 1/4 Mile ET & Speed: 11.677 @ 119.06
    STM Mustang Dyno: 390 whp / 360 wtq
    2017 Global Time Attack - Limited AWD Class
    2nd - Road Atlanta
    2017 CSCS Time Attack - Street AWD Class
    1st - Mosport DDT 1:38.391 (Record)
    1st - TMP 1:17.644 (Record)
    1st - TMP Reverse 1:23.944 (Record)
    1st - Shannonville 1:59.748 (Record)
    1,257
    72 Post(s)
    Quote Originally Posted by Hiboost View Post
    Indeed. Still recovering from my engine bay fire 8 months later.
    Evo X Harlot UT_EvoX's Avatar
    2,558
    245 Post(s)
    Russell P/N 644113. That's what you need and what we use for this connection.
    I can get you one for a lot cheaper than you see online. Send us an email sales <at> wtftuned.com
    350 WHP WW Flex Fuel 2014 Evo X MR | 600 WHP OB 2008 Evo X GSR
    Evo X Builder & Tuner since 2009 - Boosted Mitsubishis since 2005 | Buy fuel kits, flex fuel setups, or order an e-tune online: http://www.wtftuned.com/
    Follow us on Facebook: https://www.facebook.com/WTFTuned
  12. #12
    Senior Member Doc's Avatar
    Mar 2016
    186
    5 Post(s)
    ^ I agree..
    I won’t use the plastic clips on any fuel lines.. they scare me
  13. #13
    2,558
    245 Post(s)
    Quote Originally Posted by Doc View Post
    ^ I agree..
    You have to on the stock fuel rail, but I stick to one brand. We've never had anybody have issues on the horizontal connection.
  14. #14
    2,394
    218 Post(s)
    Quote Originally Posted by UT_EvoX View Post
    ^ I agree..
    I use the russel metal fitting on oem fuel rail. Radium also has a low profile one that fits
