Results 1 to 8 of 8
Thread: P0133 code
    Senior Member Evobigz's Avatar
    Phoenix, AZ
    113
    P0133 code
    So just the other day I got a code that popped up P0133. Iím assuming itís because I installed the map cast exhaust manifold and I havenít had my Evo tuned yet. My AFRís are on point except for when I get into boost little bit it does start to get really rich. So thatís why Iím assuming I got this code but would like to hear your guys input on this.
    FP BB Red turbo : Darton Sleeved 2.0 : Arias custom Pistons : Kelford - B Cams and springs : Supertech- valves : ID 1300 fuel injectors : Exedy - Twin Clutch
    BakaUnchi Tuned : Mustang Dyno 91 4010whp, e85 501whp
    1,461
    75 Post(s)
    happened right after install? i would expect the mixture to get leaner due to higher flowing exhaust manifold and cylinder emptying improvement.
    Senior Member Doc's Avatar
    Mar 2016
    186
    5 Post(s)
    I got the same code after removing and installing the same injectors.. all lines checked .. no more issues found.. thoughts?
    Phoenix, AZ
    113
    Bumb
    So after made this original post I haven’t got that P0133 code until recently . I have now gotten this code twice now in the past three weeks. At this point I don’t think it’s an exhaust leak but I haven’t fully looked over exhaust. I haven’t looked at my O2 sensor but I’ll be doing that this weekend. I’m hoping it’s just that the car needs to be returned which I am getting my car retuned here in about a month. So I would really appreciate some feedback on when you guys think you could
    Phoenix, AZ
    113
    Bump
    So over the weekend I installed a new 02 senior and of course that didnít fix it. I inspected the car underneath looking for exhaust leaks and didnít find anything. My only guess that it could be tune related?
    Sent from my iPhone using Tapatalk
    Senior Member NFSEvolutionGSR's Avatar
    Orlando
    365
    3 Post(s)
    I get a similar code from time to time. I suspect that it has to do with the fueling of the vehicle. I have not yet combed through my most recent set of logs, but I suspect that the car is running rich and is clogging the sensor.
    Now, I have gone through my entire exhaust and have replaced the sensor. No leaks that I can see, and everything is new. I will do a complete system leak test before settling on that conclusion, but there is no other explanation in the event that there are no leaks. The position of the sensor is close to OEM. Everything should be mechanically fine. I would be willing to bet that yours is fueling related, as well.
    Mayhem is everywhere.
    Phoenix, AZ
    113
    Well I think I got lucky, after I made my last post. I made one last effort and I adjusted some of my couplers that connected to my air intake and to my blow off valve. Sense then I have not got that code back ��
    Phoenix, AZ
    113
    Well after my most recent post I did get the code once again P0133. So I switched back to E85 to see what will happen. Well, I’ve been running it for the past 4 tanks and I have not been getting the code whatsoever. So for some reason this could be a tuning related for me.
