Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 165
Thread: Athanasios EFR 9174 2009 SST build
  1. #51
    Apr 2016
    Athens, Greece
    282
    Today I was going a trip off town. I was cruising at 60 mph and sudenly the engine switched off. It never fired up since then.
    It fires but does not maintain idle and the gas pedal does nothing.
    Very strange thing.
    The pump seams to work, the fuses are fine and there is no CEL light on.
    Any ideas???
  2. #52
    Senior Member razorlab's Avatar
    East Coast, somewhere
    2,547
    239 Post(s)
    What is your fuel pressure? Check your pump controller.
    Same thing happened to me when my POS Easy Performance controller took a crap. It was fun trying to find a spot to pull over safely on the hwy with zero forward power.
    My lift pump in tank was enough for the car to start but the restriction through the surge tank pump was not allowing it to stay idling, fuel pressure was around 8-10psi so I figured my main pump in the surge tank was no longer working. (because the pump controller died).
    Also check the connections on top of the radium pump hanger. They can get loose if you don't double nut them.
  3. #53
    Apr 2016
    Athens, Greece
    282
    I can't manage to see the fuel pressure reading, because it fires for 1 second. It reads something like 0.6 bar when off.
    I tried to power directly the second pump with 14v but still no success.
    I didn't check the connection to the hanger, but there was no fuel smell around.
    Also, I don't use fuel controllers. Only 1 pump at 8v on idle and cruise and the 2nd one chime in when at 14v.
    Thanks for the reply man...
  4. #54
    Oct 2015
    Brazil
    329
    69 Post(s)
    Try to start your engine with shift lever in neutral, it won't run the starter but you should be able to check the fuel pressure.
  5. #55
    Apr 2016
    Athens, Greece
    282
    Just transferred the car back home.
    We gave power to the pump directly from an other battery and it reaches 2.4 bar fuel pressure, but still it fires, stays for a few seconds at idle and shuts off.
    We did a compression test with the motor cold, checked the throttle body and bupassed the fuel pump hi low relay. Still no solution.
    Culinder no. 1 :
    2 :
    3 :
    4 :
  6. #56
    Apr 2016
    Athens, Greece
    282
  7. #57
    Apr 2016
    Athens, Greece
    282
    The issue here is really weird , it has air , fuel and spark, but something tells it to shut off.
    Do you guys think it could be the immobilizer???
  8. #58
    51
    Could have jumped a tooth, are you getting any codes?
  9. #59
    2,547
    239 Post(s)
    Have you tried it with MAF disconnected?
  10. #60
    Senior Member mityaz's Avatar
    Sep 2016
    1,563
    79 Post(s)
    There may be some kind of delay for closed loop to kick in. So while you are running in open loop during first few seconds it's fine, but then it goes into a closed loop which it cant maintain for whatever reason
    Sent from my SM-G950U using Tapatalk
    '11 GSR
    current: same exact as last. new block, new head. no kaboom yet.
    2.05L/darton,ProH,CP 10:1 w/Ultimate pins. IWG9174 .92. GSC-S2. 4P head +1mm In/Ex. <--KABOOM (blown HG)
    Past: 2.4L,Manley94,Pro-H,Wiseco,10:1,Darton,4P head,GSC all,Supertec valves,FR 9174 IWG .92,2x450 Walbro/EP control,ID1700,Flex,OSGiken triple. <--KABOOM (spun rod bearing)
  11. #61
    Apr 2016
    Athens, Greece
    282
    Quote Originally Posted by toothless View Post
    There are no CEL codes. Only the gost p0219 pending fault that many running evos live with.
  12. #62
    Apr 2016
    Athens, Greece
    282
    Quote Originally Posted by razorlab View Post
    Just tried with disconnected MAF and it did not fire at all.
    It pulled the following codes when I tried with the MAF disconnected
    P1590
    U0101
    P0102
    P0113
    But I suppose this is normal
  13. #63
    Apr 2016
    Athens, Greece
    282
    The element of the Fuellab fuel filter was the fault.
    Just removed it and everything ok.
    I had this filter 4 years and almost 30,000klms
    Thank you all for your input...
  14. #64
    Apr 2016
    Athens, Greece
    282
    Problem solved , so I did the first test with 50/50 meth/water injection.
    29psi boost , 11.6 AFR, 82% IDC
  15. #65
    Apr 2016
    Athens, Greece
    282
    Another problem came out today
    Doing some 3rd gear WOT pulls to check for potential knock with headphones and sudenly the "service required" poped up.
    The code that I pull is P1827 Shift fork position sensor 2 system ( Output range out)
    The car drives with 2nd 4th and 6th only, no 1st 3rd 5th and no reverse.
    Probably the shift fork magnet is somewhere between the gears into pieces...
  16. #66
    Senior Member Mnemuth's Avatar
    1,227
    48 Post(s)
    Quote Originally Posted by athanasiosnoir View Post
    I drove 6 hours home from Mid Ohio once with just odd gears. The magnet stuck to the steel rod that moves the fork. What a stupid problem to have...
    The finger cannot point at itself.
  17. #67
    Apr 2016
    Moscow/Russia
    140
    4 Post(s)
    What size of meth injectors you use?
  18. #68
    Apr 2016
    Moscow/Russia
    140
    4 Post(s)
    Its very strange thing. Usualy magnet of 4th gear fork make this and you have only 1-3-5-R gears.
  19. #69
    Apr 2016
    Athens, Greece
    282
    Quote Originally Posted by 0uch.! View Post
    Used the 2 larger jets that I had with the kit I 've purchased, 420cc and 570cc, if I remember correctly. And the largest restrictor, 0.9mm. Do you suggest something else?
  20. #70
    Apr 2016
    Athens, Greece
    282
    Yes, you right about this. In a few days we are going to find out the root cause of this issue , since the SST is going out . When I had the Dodson magnet installed, it didn't drive with 2nd 4th and 6th. What a pity I had to open the trans again and put the stock magnet back in. Now it's the exact opossite .
  21. #71
    Apr 2016
    Athens, Greece
    282
  22. #72
    Apr 2016
    Moscow/Russia
    140
    4 Post(s)
    It's to small jets ! We use for our SST car with S366 2xlarger AEM jets( 2x1000cc). But our turbo have 87lb, yours 95lb!! Alternatively, you can drill a hole of larger diameter in the jets or buy one more jets kit and mount 2 jets more. And unmount restrictor - i think you dont need that thing...
  23. #73
    Apr 2016
    Athens, Greece
    282
    It's to small jets ! We use for our SST car with S366 2xlarger AEM jets( 2x1000cc). But our turbo have 87lbs, yours 95lbs!! Alternatively, you can drill a hole of larger diameter in the jets or buy one more jets kit and mount 2 jets more. And unmount restrictor - i think you dont need that thing...
    You are probably right that I need some more jets.
    The turbo is bigger than the one you use to the SST car but you boost it more. I am only at 2.1 bar of boost , still on the stock 3bar MAP sensor.
  24. #74
    Apr 2016
    Moscow/Russia
    140
    4 Post(s)
    I mount 1x1000cc jet to the car(s) with ~3076gtx and 2bars boost. And boost is not a main thing , main thing is an airflow by the turbo.
  25. #75
    Apr 2016
    Athens, Greece
    282
    What is the % meth / water mix you are using at those cars?
    Because, the bigger the meth % , the bigger the jets you need.
    I am on 50 50 mix for the beginning.
Tags for this Thread
