Page 6 of 6 FirstFirst ... 456
Results 126 to 143 of 143
Thread: Athanasios EFR 9174 2009 SST build
  1. #126
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Installed the ID1700x injectors and after some sort period of tuning, did some tests today.
    4th gear pull at 2.3 bar
    First test of the Dragy device
    Began the pull with 2nd gear, at a slight upward road, with traffic and reached 200 klms per hour with 5th gear, instead of 4th.
    So, I have a feeling that the car could go an easy 4.5 sec for 100 - 200 kph.
  2. #127
    Senior Member EVOL ME's Avatar
    Boise
    589
    18 Post(s)
    I am still figuring out the tuning side and all. Does your explanation of
    Road explain the lean spot at 5,500 rpm or so?
  3. #128
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Quote Originally Posted by EVOL ME View Post
    Take a look at the latest pull I did today, with some changes at the fuel calibration map close to the 5500 -7500 rpm area.
  4. #129
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Test done again. This time I started with 2nd gear and reached 200kph with 4th close to 9000 rpm.
  5. #130
    Senior Member DereksX's Avatar
    St. Louis, MO
    1,370
    53 Post(s)
    Fast car right there! Good to see it running well man! What is your IDC?
    WTF 2.0 in Progress
  6. #131
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Quote Originally Posted by DereksX View Post
    Thanks Derek... 84-88% at 9000rpm
    Remember, I am on pump fuel (100 octane)
  7. #132
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    The SST did it's thing again today. The P1833 code is now there all day long. Even gears are out and the transmission is going to be opened again in a few weeks. So, let's see what happened this time. All plastic magnets are secured well with screws...
  8. #133
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Found the root cause.
    The 2/4 magnet was moving despite the fact that there was a screw inside. It just couldn't move completely out.
    Now I am going to try with Dodson s latest (version 6) 2/4 shift fork magnet. And hope for the best of luck. Last time I 've tested a Dodson magnet (older version) it was a complete failure.
  9. #134
    1,461
    75 Post(s)
    props to you and your man-hours for continuing to go ahead. 98% of the people out there would have quit by now.
    I was damn sure that your bolt/nylon insert nut was going to be plenty for the magnet. but i guess not
  10. #135
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    I never quit man. It is the 6th time we open the transmission the last 3 years. And trying to do it better each and every time. But something/s are going wrong each time...
  11. #136
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
  12. #137
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    New plans for 2019,
    Syvecs P&P ECU
    Borg Warner EFR 9274
    Custom billet intake manifold
    4bar MAP sensor
    VP import and all the boost!!!
    Of course, if the Dodson magnet works properly. Lol
  13. #138
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Everything ready to fit.
    Tik tak tik tak tik tak
  14. #139
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    The Dodson V6.0 magnet worked fine, only after the Shift Fork Teach In. Before that it wouldn't engage into 4th gear.
    So, the 2019 plan continues as expected.
    Already ordered the Syvecs ECU and waiting for the EFR 9274 to be released within the next 4 weeks...
  15. #140
    Junior Member
    Jan 2016
    Paris, France
    2
    Quote Originally Posted by athanasiosnoir View Post
    Hi man, is the Syvecs with SST support already available? My supplier told me it was going to be released in early February, I've been waiting to pull the trigger on it since they launched the 5spd version.
    Envoyé de mon SHT-W09 en utilisant Tapatalk
  16. #141
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Quote Originally Posted by pepinorang View Post
    Syvecs uses their new S7+ ECU for the evo X SST platform and the release of it is on February. They agreed to have an OEM ECU sent to them, but i still don't know when they are going to send me the S7+ p&p.
  17. #142
    May 2018
    36
    What is the benefit of the Syvecs over the Motec unit?
  18. #143
    Apr 2016
    Athens, Greece
    265
    2 Post(s)
    Quote Originally Posted by ddlopresti View Post
    I don't think there is a benefit. I am pretty sure that motec is better, but they don't offer a P&P ECU supporting SST transmission.
Tags for this Thread
