Results 1 to 3 of 3
Thread: 2014 Outlander Nav into 2015 EVO X?
    Indio, CA
    176
    9 Post(s)
    I want to say this will work, but I cant seem to find a definitive answer. Looks like the 2014 EVO NAV and 2014 Outlander NAV have different part numbers as well. Does anyone know? Is this a PnP install?
    Senior Member NFSEvolutionGSR's Avatar
    Orlando
    372
    If you have a specific unit in mind, post pictures of the back of it.
    Mayhem is everywhere.
    Indio, CA
    176
    9 Post(s)
    Quote Originally Posted by NFSEvolutionGSR View Post
    Short answer is yes it will work. There is a harness taped up in the back corner with a dummy plug inserted into it. Remove dummy plug and connect to the head unit. The only thing that won't work is a small external box p/n 8750A403. This part is strictly Outlander and does not need to be installed in an EVO X. You re-use your cage/brackets off your oem touchpanel and you re-use the oem dash bezel. Pretty straight forward install.
