Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: FS: 2010 Evo X S.Fl 20k
  1. #26
    212
    5 Post(s)
    Bumpity bump
  2. #27
    212
    5 Post(s)
    Somebody delete this thread please. Thanks
  3. #28
    751
    4 Post(s)
    did it sell, im in the market
  4. #29
    2,274
    196 Post(s)
    I ended up picking this up and got it all fixed if anyone is interested
  5. #30
    751
    4 Post(s)
    Quote Originally Posted by Black E View Post
    might want to list whats all been done, it just has photos right now
  6. #31
    2,274
    196 Post(s)
    Quote Originally Posted by yeayeaatou View Post
    ENGINE:
    PSIPROformance built 2.2 STROKER MOTOR.
    MANLEY 4340 BILLET 94MM STROKE TURBO TUFF SERIES CRANKSHAFT
    MANLEY TURBO TUFF I BEAM CONNECTING RODS
    MANLEY 86MM STANDARD BORE 9.0:1 DISH PISTON SET WITH RINGS
    DARTON SLEEVES
    ACL HIGH PERFORMANCE RACE BEARING SET
    ACL HIGH PERFORMANCE MAIN BARING SET
    ACL THRUST WASHER
    COSWORTH FSL HEADGASKET 86.5MM
    MITSUBISHI MASTER GASKET SET
    ALL NEW GUIDES AND CHAINS
    ALL NEW PUMPS
    HIGH VOLUME OIL PUMP
    NEW MITSUBISHI OIL PAN
    HEAD:
    PSIPROformance STREET PORTING AND POLISH
    NEW GUIDES, CLEANED, DECKED, etc.
    SUPERTECH INCONEL EXHAUST VALVES OVERSIZED +1MM
    SUPERTECH BLACK NITRIDE INTAKE VALVES OVERSIZED +1mm
    FERREA EXHAUST VALVE GUIDE
    FERREA INTAKE VALVE GUIDE
    FERREA VALVE STEM SEALS
    ARP ULTIMATE DUTY 625+ HEAD STUDS
    GSC S2 CAMS
    TURBO:
    CUSTOM PSIPROformance SIDEWINDER MANIFOLD
    PRECISION PTB505-6266 BALL BEARING TURBO
    PSO PROformance DUMP TUBE
    PSI PROFORMANCE CUSTOM DOWN PIPE
    TIAL 44MM WASTEGATE BLACK
    TIAL QR 10PSI BLACK BOV
    PSI EVO X FMIC KIT WITH PIPING
    DEI TITANIUM TURBO BLANKET
    PSI PRO OIL COOLER KIT WITH STAINLESS LINE AND MODIFIED OIL PAN SYSTEM AND FITTINGS
    GRIMMSPEED EBCS
    FUEL:
    BUSCHUR DOUBLE PUMPER WITH TWIN WALBRO 255’s
    AMS BLACK RUEL RAIL
    FIC 2150cc INJECTORS
    STEEL BRAIDED FUEL LINES
    TRANS:
    SHEP TRANS TOOL STEEL DIFF PIN KIT
    SHEP TRANS SHIFT PIN KIT
    EXEDY RACING STAGE 4 TWIN METALLIC CLUTCH KIT
    REDLINE 75W90 GEAR OIL
    AMS CLUTCH MASTER CYLINDER UPGRADE
    NEW OEM CLUTCH RELEASE BEARING
    SUSPENSION/BRAKES:
    WHITELINE HEAVY DUTY ADJUSTABLE FRONT SWAY BAR 27MM
    WHITELINE HEAVY DUTY ADJUSTABLE REAR SWAY BAR 27MM
    WHITELINE SWAY BAR ALUMINUM 27MM LATERAL LOCK KITS
    KW V3 COILOVER KIT
    DBA FRONT DRILLED AND SLOTTED 5000 SERIES 2 PIECE ROTORS W/GOLD HAT
    DBA REAR DRILLED AND SLOTTED 4000 SERIES ROTOR
    EBC YELLOW STUFF FRONT BRAKE PADS
    EBC YELLOW STUFF REAR BRAKE PADS
    AMS SS BRAKE LINE KIT
    The car does have a “rebuilt/flood/totaled” tittle. The car had the OEM engine hydrolocked and the owner put it through the insurance, so they totaled it.
    Now the car does not have a “rebuilt” red sticker on the A pillar and does not have a red “rebuild” tittle either. Instead it has a regular blue FL tittle but it does have “flood damage” on it.
    Just want to be clear so that people don’t get the wrong impression, I’m not trying to scam anyone.
    Because of this I’m asking $18,500 for the car.
    I’ll post some more pictures in the next few days.
