Page 1 of 7 123 ... LastLast
Results 1 to 25 of 159
Thread: Joeyrukkus Build THRAD 2012 WW GSR journey to T4
    Global Moderator
    311
    12 Post(s)
    Build parts list updated 2/4/2016
    H&R Lowering Springs
    ETS Intake (Will be for sale after turbo kit goes on)
    ETS HFC (Not installed)
    Test pipe
    ETS 4in Intercooler
    ETS V2 Quiet CBE
    ETS LICP
    Grimmspeed EBCS
    Synapse DV
    Innovate LC-1 WB
    Innovate AFR Gauge
    AEM 50 PSI Boost Gauge
    Perrin Gauge cups
    MAP Fuel Pump Install kit
    Modified fuel basket Walboro 450
    Kozmic valve cover fittings
    Kozmic Cam Sensor heat sheild
    Firewall Heatshield
    Driven Fabrication Catch can 10an
    Radium Fuel Rail + Damper
    ID 2000 Injectors
    Omni 4 Bar Map Sensor (Not installed)
    Tatrix with OBDII extension
    Magnus Evo 9 CMC Conversion
    08 Aluminum valve cover
    Fuel Lab 4 micron 8an fuel filter
    Fuel Lab FPR
    Summit Premium -8 fuel line
    Summit Premium -6 return line
    MAP Twin Scroll T4 kit w/ PTE 6266bb
    -Turbosmart comp 40 waste gates
    -Forced Performance oil feed filter
    Ported head by P and R engine
    Kelford C cams
    Kelford Springs
    Supertech 1mm+ Valves
    QM 8-leg clutch w/ Hydraulic TOB conversion
    AEM Fuel/Oil pressure gauge
    Custom Rear camber arms
    WTF E85 Tune
    Enkie Raijin 18x9.5
    Hub centric rings
    Mutegi lugs
    Michilen Pilot super sports 265/35/18
    DEI turbo blanket and manifold wrap
    Powder Coat by Detective coatings
    Driven Fab Valve Cover bolts
    MAP Billet timing chain guide
    AMS oil pressure remote sensor line
    Torque Solutions Thermal IM gasket
    Weisco 10.5:1 Pistons upgraded wrist pins
    Manley Turbo Tuff I beam rods
    King Race Bearings
    ARP Main bolts
    ARP Head studs
    Darton Sleeves
    ATI Super Damper
    Kenne Bell Boost a pump
    Global Moderator
    311
    12 Post(s)
    I kinda gave up on rebuilding this thread lol
    Ok update!
    So in addition to paying down some debt to be able to afford this build I knew that at some point one of the most important mods of all was going to need to happen, beater car. I got the summer tires earlier in the spring so i figured I would either need snow tires for the stock rims OR that long awaited beater car mod. I started looking in the 3500 dollar range for some honda or possibly a truck that could potentially tow the evo if the worst happens. I looked at a few things that were either too beat up or just looked crappy. Then I came across what I now refer to as "Monster Beater Truck" MBT for short. It's a 96 Tahoe with a giant lift and custom rear tire holder/roof rack. The guy that built it was super into search and rescue I guess. It has rust but nothing like falling apart wise, runs good and the tranny has been rebuilt recently. So basically I traded race car problems for giant old truck problems.
    I'm going to store the Evo for the winter and keep saving and collecting parts. Longest build ever right?
    I found a garage for rent 10 min walk from my house, going to get the control arms on, oil change, pump gas in the tank and car washed really good. Still need to get a battery tender or something.
    Senior Member Nate's Avatar
    Pittsburgh, PA
    2,546
    Holy shit man, that thing is massive. Should be able to handle any potholes or snow in the burgh like a chief.
    2010 GG Evo X
    Power:
    AMS Down-pipe, MAP Resonated TP, UR Dual Exhaust, ETS Intake, Grimspeed 3 Port, Synapse DV, AMS Inter-cooler, MAP UICP and
    Tuned by Chet using EcuFlash
    Interior:
    AEM Boost and Wideband Gauges
    Suspension & Handling:
    Ohlin R&T Coilovers w/ 10k/10k springs
    Senior Member Kratos's Avatar
    126
    I came in here to see car.... & i only see truck. why...
    Senior Member evostanman's Avatar
    SoCal
    398
    8 Post(s)
    Quote Originally Posted by Kratos View Post
    greatness awaits...
    2006 Evo IX GSR
    2013 Evo X GSR E85 387WHP/409WTQ (RIP)
    Global Mod of Things DKevoX's Avatar
    1,868
    97 Post(s)
    dude that truck is HUGE wow. That's a sweet beater. Hopefully doesn't cause you too many problems!
    Senior Member lew-e's Avatar
    1,280
    28 Post(s)
    Sweet ass beater truck! I was in the same boat and my dad just offered to give me his 2005 Hyundai sonata. Nothing fancy but it will save me miles on the evo!
    Sent from my HTC One_M8 using Tapatalk
    Global Moderator
    311
    12 Post(s)
    I also decided, come spring time even if I don't have the bottom end built yet, the turbo kit is going on.
    Quote Originally Posted by joeyrukkus View Post
    I like dis.
    Global Moderator
    311
    12 Post(s)
    Need to meet up with @Funwad to wrap the mani and have to run the intake and UICP up to a place for powder coating, then start puttin this thing together.
    300
    13 Post(s)
    Lots of shiny new parts... Fun times ahead for you
    Sent from my iPhone using Tapatalk
    Global Moderator
    311
    12 Post(s)
    Wrapped the dump tubes and downpipe, waiting on a filter from FP.
    Senior Member flawlessninja's Avatar
    Arizona
    1,457
    29 Post(s)
    @stephenemersondickens
    2012 PBP Evo X GSR
    WTF Tuned | Flex Fuel | Full ETS Bolt-Ons | Íhlins/SuperPro/Torque Solution Suspension
    SM #11
    SCCA Member # 467273 ← Use me as a referral for a membership discount!!
    NASA Member # 179774
    Nice progress, Joey. Can't wait to get this thing tuned!
    Global Moderator
    311
    12 Post(s)
    Little progress, took a trip to Summit with @Funwad yesterday. Picked up a bunch of fittings, heat sheath for the oil feed, and oh just a magical 800hp fuel basket.
    Once I get the fuel lines mostly fitted and assembled it might be go time for turbo install.
    Global Moderator
    311
    12 Post(s)
    Eff it feels good to get this stuff out of the closet and onto my table, can't wait to get it on the car.
    Senior Member LeesEvoX's Avatar
    Houston, TX
    1,553
    87 Post(s)
    what do you mean by 800hp fuel basket? i am running into issues on my set up now with the fuel basket emptying qyicker than it can fill up... very interested to hear about zis......
    Sent from my SM-G900T using Tapatalk
    Global Moderator
    311
    12 Post(s)
    Quote Originally Posted by LeesEvoX View Post
    This is the basket out of @Funwads car, he made 810hp with it. He modified it similar to how Englando did. Plus ran a boost a pump, big lines and big injectors.
    Member Funwad's Avatar
    Pittsburgh, PA
    56
    23 Post(s)
    I made that power with a Kenny bell boost-a-pump wired up as well, so it wasn't just the modified basket that did it
    Houston, TX
    1,553
    87 Post(s)
    Quote Originally Posted by Funwad View Post
    what did you modify? is there a write up?
    Global Moderator
    311
    12 Post(s)
    Bulkhead fittings so there is no bottle neck to get out of the basket, go check out englandos build thread on the other forum, thats the closest there is to a write up.
    Houston, TX
    1,553
    87 Post(s)
    you're a star!
    Global Moderator
    311
    12 Post(s)
    Pulled my head from the basement so I can get it checked out to make sure it's in perfect working condition when it goes in the car.
    Speed Circuit built it and did a piss poor job shipping it so better safe than sorry.
    Going to put it on with the turbo kit?
    Senior Member pistolpete69916's Avatar
    CO
    1,584
    That truck is so murica. You should paint a big penis on the hood.
